- Mute
- Permalink
- Report
As far as Autodesk deliberetly ignores customer's requests (archived corresponding idea*) for adding ability to set default ProjectionType to "Perspective With Ortho Faces" I suggest try to invent some trick ourselves.
For example is it possible to emulate calling for ViewCube content menu and then (after a bit delay) emulate pressing "F" (or another "underlined" key according to current Inventor session localization)?
..and hook this to activatation of 3Dmodel's graphic window.
Please vote for Inventor-Idea Text Search within Option Names
- Mute
- Permalink
- Report
I expect that the option PerspectiveWithOrthoFaces is a combination of settings of the camera. If you can figure out what those settings are then you can make an iLogic rule with those settings. That rule could be triggerd on opening of each file? (i couldn't find the correct settings)
Anyway you can check the camera settings like this.
Dim cam As Camera = ThisApplication.ActiveView.Camera MsgBox(cam.Perspective & " - " & cam.PerspectiveAngle)
The properties Perspective and PerspectiveAngle are shown here in a msgbox. More properties can be found in the help files.
If you know what those settings are then your settings rule could look like this:
Dim cam As Camera = ThisApplication.ActiveView.Camera cam.Perspective = True cam.PerspectiveAngle = 0.00001 cam.Apply()
Maby you want to learn more about working with the camera api, a good starting point are these posts by @BrianEkins
https://modthemachine.typepad.com/my_weblog/2013/09/working-with-cameras-part-1.html
https://modthemachine.typepad.com/my_weblog/2013/09/working-with-cameras-part-2.html
Jelte de Jong
Blog: hjalte.nl - github.com
- Mute
- Permalink
- Report
"Customer solution" that did the trick for me available here - https://forums.autodesk.com/t5/inventor-forum/set-perspective-with-ortho-facesas-the-default-project...
