11-18-2019
06:50 AM
- Mute
- Permalink
- Report
11-18-2019
06:50 AM
You're right, thank you. The bold section is where the file copy is created, saved and checked in to Vault. When it is created, it goes through an Event Triggered piece of code which starts the sketch process for a base drawing. To either stop the base drawing process at this point or limit it to one go or something like that is what I'm after. Thank you.
Dim modelname As String
Dim odoc As Document
iLogicForm.Show("Save Drawing")
modelname = iProperties.Value("Summary", "Title")
If saved = True Then
ThisDoc.Document.saveasinventordwg("[MACHINE DRAWING FIEPATH]" & modelname & ".dwg", True)
oFileName = ThisDoc.FileName(False) 'without extension
oRevNum = iProperties.Value("Project", "Revision Number")
oPDFAddIn = ThisApplication.ApplicationAddIns.ItemById("{0AC6FD96-2F4D-42CE-8BE0-8AEA580399E4}")
oDocument = ThisApplication.ActiveDocument
oContext = ThisApplication.TransientObjects.CreateTranslationContext
oContext.Type = IOMechanismEnum.kFileBrowseIOMechanism
oOptions = ThisApplication.TransientObjects.CreateNameValueMap
oDataMedium = ThisApplication.TransientObjects.CreateDataMedium
oOptions.Value("All_Color_AS_Black") = 1
oOptions.Value("Remove_Line_Weights") = 1
oOptions.Value("Vector_Resolution") = 400
oOptions.Value("Sheet_Range") = Inventor.PrintRangeEnum.kPrintAllSheets
'get PDF target folder path
oFolder = "[PDF DRAWING FILEPATH]"
'Check for the PDF folder and create it if it does not exist
If Not System.IO.Directory.Exists(oFolder) Then
System.IO.Directory.CreateDirectory(oFolder)
End If
'Set the PDF target file name
oDataMedium.FileName = oFolder & "\" & modelname & ".pdf"
'Publish document
oPDFAddIn.SaveCopyAs(oDocument, oContext, oOptions, oDataMedium)
thisapplication.Documents.Open("[MACHINE DRAWING FILEPATH]" & modelname & ".dwg")
ThisApplication.CommandManager.ControlDefinitions.Item("VaultCheckinTop").Execute2(False)
Else
Logger.Debug("saved?: " & saved)
Exit Sub
End If
saved = False
