- Mute
- Permalink
- Report
BOM filter with view representation using ilogic
Can any one help me how to filter the BOM based on view representation using ilogic.
I want to automate this feature with assembly parameter.
Can any one share the sample examples.
- Mute
- Permalink
- Report
- Mute
- Permalink
- Report
- Mute
- Permalink
- Report
I also have looked into this issue. I don't see any access to the "Filter Settings" of the PartsList. You can access the MemberSelection, PartsListStyle, and many other aspects of it, but not the one your looking for.
Try searching the Inventor Ideas forum. If you don't find anything about it there, you can post the idea of including this access.
Wesley Crihfield
(Not an Autodesk Employee)
- Mute
- Permalink
- Report
i could not find a way to set the default filters but you could create your own filter. The following i logic code will filter all rows that have the letter "e" in the 3e cell. (that is ofcource not usefull but maby a start point for your own filter)
Dim doc As DrawingDocument = ThisApplication.ActiveDocument
Dim sheet As Sheet = doc.ActiveSheet
For Each row As PartsListRow In sheet.PartsLists.Item(1).PartsListRows
Dim cell As PartsListCell = row.Item(3)
If (cell.Value.Contains("e")) Then
row.Visible = False
Else
row.Visible = True
End If
Next
Jelte de Jong
Blog: hjalte.nl - github.com
