- Mute
- Permalink
- Report
Hi Guys,
I'm trying to find out how to check in a file that I have already saved a different copy of with a different name than the original. Fo example, original model may be called '0123456.ipt' but once my rule runs, the machine drawing becomes '0123456 - 50mm.ipt' etc. I would like to be able to check in this machine drawing version as I am saving it if possible. I've already tried to find the information on here and the greater Internet and found the info here very useful (https://forums.autodesk.com/t5/inventor-forum/ilogic-check-in-drawing-into-vault/td-p/4735987) but it checks in my original file and I'm not good enough in Inventor to wriggle my way around this one.
Any help is much appreciated.
Dim modelname As String
Dim odoc As Document
'saved = False
iLogicForm.Show("Save Drawing")
modelname = iProperties.Value("Summary", "Title")
If saved = True Then
ThisDoc.Document.saveasinventordwg("[MACHINE DRAWING FILEPATH]" & modelname & ".dwg", True)
'oPath = ThisDoc.Path
oFileName = ThisDoc.FileName(False) 'without extension
oRevNum = iProperties.Value("Project", "Revision Number")
oPDFAddIn = ThisApplication.ApplicationAddIns.ItemById("{0AC6FD96-2F4D-42CE-8BE0-8AEA580399E4}")
oDocument = ThisApplication.ActiveDocument
oContext = ThisApplication.TransientObjects.CreateTranslationContext
oContext.Type = IOMechanismEnum.kFileBrowseIOMechanism
oOptions = ThisApplication.TransientObjects.CreateNameValueMap
oDataMedium = ThisApplication.TransientObjects.CreateDataMedium
'oFolder = "[FILEPATH]"
'If oPDFAddIn.HasSaveCopyAsOptions(oDataMedium, oContext, oOptions) Then
oOptions.Value("All_Color_AS_Black") = 1
oOptions.Value("Remove_Line_Weights") = 1
oOptions.Value("Vector_Resolution") = 400
oOptions.Value("Sheet_Range") = Inventor.PrintRangeEnum.kPrintAllSheets
'oOptions.Value("Custom_Begin_Sheet") = 2
'oOptions.Value("Custom_End_Sheet") = 4
'End If
'get PDF target folder path
oFolder = "[PDF DRAWING FILEPATH]"
'Check for the PDF folder and create it if it does not exist
If Not System.IO.Directory.Exists(oFolder) Then
System.IO.Directory.CreateDirectory(oFolder)
End If
'Set the PDF target file name
oDataMedium.FileName = oFolder & "\" & modelname & ".pdf"
'Publish document
oPDFAddIn.SaveCopyAs(oDocument, oContext, oOptions, oDataMedium)
ThisApplication.CommandManager.ControlDefinitions.Item("VaultCheckinTop").Execute2(False)
Else
Logger.Debug("saved?: " & saved)
Exit Sub
End If
saved = False
