jjstr8
I ran a quick test in VBA to grab RangeBox coords on all planar surfaces.
Sub EdgeLoopTest()
Dim app As Application
Set app = ThisApplication
Dim doc As Document
Set doc = app.ActiveDocument
Dim startTime As Date, endTime As Date
startTime = Now()
If doc.DocumentType = kPartDocumentObject Then
    Dim count As Integer
    Dim pDoc As PartDocument
Set pDoc = doc Dim cDef As ComponentDefinition Set cDef = pDoc.ComponentDefinition Dim srfBods As SurfaceBodies Set srfBods = cDef.SurfaceBodies Dim srfBod As SurfaceBody For Each srfBod In srfBods If srfBod.IsSolid Then Dim sFaces As Faces Set sFaces = srfBod.Faces Dim sFace As Face Dim eLoop As EdgeLoop For Each sFace In sFaces If sFace.SurfaceType = kPlaneSurface Then For Each eLoop In sFace.EdgeLoops 'Dim x1 As Integer, x2 As Integer, y1 As Integer 'Dim y2 As Integer, z1 As Integer, z2 As Integer Dim mn() As Double Dim mx() As Double eLoop.RangeBox.MinPoint.GetPointData mn eLoop.RangeBox.MaxPoint.GetPointData mx 'x1 = eLoop.RangeBox.MinPoint.x 'y1 = eLoop.RangeBox.MinPoint.y 'z1 = eLoop.RangeBox.MinPoint.z 'x2 = eLoop.RangeBox.MaxPoint.x 'y2 = eLoop.RangeBox.MaxPoint.y 'z2 = eLoop.RangeBox.MaxPoint.z count = count + 1 Next End If Next End If Next End If endTime = Now() End Sub
The part I tested had over 4800 faces and it ran in less than a second.  I tried it with both the GetPointData and directly getting the XYZ properties.  Same amount of time on both ways.  I haven't tried it in an addin in c#.  I'm not sure why it's so slow for you?
