- Mute
- Permalink
- Report
Hi DanV,
Thanks for your response.
My goal is this:
We create new drawings for every part or assembly and we use the same template.
For parts, there will only be one sheet per drawing, but for assemblies, we add a sheet for a production specific partslist.
I would like to add the sheet for the assembly file that is on the first sheet.
I have code (written by Curtis Waguespack) to check the Views on the sheet to see whether a part or assembly has been placed and then call a specific function. But I wanted to see if I can rather just check the file placed in the drawing, determine whether it is a part or assembly, and then place the second sheet if it is an assembly.
The code below checks the views, if they are of an assembly, it checks if the model file has a Design view named colour and the writes the colour to a custom iproperty that I use in the title block. If we can't just verify whether the referenced file is an assembly, I would like to run through the views and place the sheet, based on existing Sheet Format.
Thank you in advance for your further assistance.
Sub Main
' Get the active drawing document.
Dim oDoc As DrawingDocument
oDoc = ThisApplication.ActiveDocument
Dim oSheet As Sheet
oSheet = oDoc.ActiveSheet
Dim oViews As DrawingViews
Dim oView As DrawingView
'get the collection of view on the sheet
oViews = oSheet.DrawingViews
' Iterate through the views on the sheet
For Each oView In oViews
Dim docDesc As DocumentDescriptor
docDesc = oView.ReferencedDocumentDescriptor
' Verify that the drawing view is of an assembly.
If docDesc.ReferencedDocumentType <> kAssemblyDocumentObject Then
Continue For
End If
' Get the component definition for the assembly.
Dim asmDef As AssemblyComponentDefinition
asmDef = docDesc.ReferencedDocument.ComponentDefinition
'define view rep collection
Dim oViewReps As DesignViewRepresentations
oViewReps = asmDef.RepresentationsManager.DesignViewRepresentations
oColourViewRepFound = False
For Each oViewRep In oViewReps
If oViewRep.Name = "Colour" Then
oColourViewRepFound = True
End If
Next
If oColourViewRepFound = True Then
Call ProcessAssemblyColor(oView, asmDef.Occurrences)
End If
Next
End Sub
Private Sub ProcessAssemblyColor(drawView As DrawingView, _
Occurrences As ComponentOccurrences)
' Iterate through the current collection of occurrences.
Dim occ As ComponentOccurrence
For Each occ In Occurrences
' Check to see if this occurrence is a part or assembly.
If occ.DefinitionDocumentType = kPartDocumentObject Then
' Get the render style of the occurrence.
Dim color As RenderStyle
Dim sourceType As StyleSourceTypeEnum
color = occ.GetRenderStyle(sourceType)
If color.name IsNot Nothing Then
iProperties.Value("Custom", "Lackierung") = color.name
Exit For
End If
End If
Next
End Sub
