mostafamahmoudseddek94
372 Views, 3 Replies
setting fastener size using API
Sub main()
Dim oDoc As PartDocument
Set oDoc = ThisApplication.ActiveDocument
Dim oHoleF As HoleFeatures
Set oHoleF = oDoc.ComponentDefinition.Features.HoleFeatures
oHoleF.Item(3).ClearanceInfo.FastenerSize = "M10"
    MsgBox (oHoleF.Item(3).ClearanceInfo.FastenerType)
Hello, I am new to the API
through this code, I am trying to set the fastener size to be a specific value based on a specific parameter. the programming/API Help informed that the "FastenerSize" is a read-write property to set or get the fastener size so how can I use this method to set the fastener size, Although using this code introduces error for me " Run-time error 445, Object doesn't support this action".
noting that this is the only thing in the hole feature that will change as shown in the figure below and all other choices will be constant with a different configuration of the model.
thanks
You have to create new HoleClearanceInfo and then replace target ClearanceInfo with new one.
Sub main()
    Dim oHole As HoleFeature
    Set oHole = oHoleF.Item(3)
    Dim oOriginal As HoleClearanceInfo
    Set oOriginal = oHole.ClearanceInfo
    Dim oChanged As HoleClearanceInfo
    Set oChanged = oHoleF.CreateClearanceInfo(oOriginal.FastenerStandard, oOriginal.FastenerType, "M10", oOriginal.FastenerFitType)
    oHole.ClearanceInfo = oChanged
    MsgBox (oHoleF.Item(1).ClearanceInfo.FastenerType)
End Sub
See also :
https://modthemachine.typepad.com/my_weblog/2019/07/new-apis-in-inventor-20201.html
Ah, it is written in the above blog that this API is added to Inventor 2020.1.
If you use Inventor 2019, it will be difficult to change the parameter...
Freeradical
 Hideo Yamada
Freeradical
 Hideo Yamada
https://www.freeradical.jp
Thanks for your code.
yes, you are right!!, the code did not run.
But for beginner person like me, how Can I know that I need to construct a new clearance info.!!, I mean I did searching in the Inventor Programming help and no indication for this also, I used Watch window too and the type of massage error has no information.
Thanks.
Let's Google!!
https://www.google.com/search?q=HoleClearanceInfo+inventor
Or ask in this forum!
Freeradical
 Hideo Yamada
Freeradical
 Hideo Yamada
