marcin_otreba
hi,
save copy as works like this when used in code. if savecopyas is set to true it only saves new copy of file. if is set to false it saves and replace file in all opened documents. also in your scenario it open it in background as invisible file. my proposoal for you is use savecopyas with true value, then use replace functionality in assembly file. Whats about vault you can determine if file is in vault and you even can refresh it by ilogic.
