Hi @HideoYamada @marcin_otręba ,
Any idea how to be sure that the userform or the usercontrol scales to the Dockable window?
At the moment the Userform scales weird (to large) and does not fit the Dockable Window size.
I have set the userform to a fix height and now the buttons are visible, but is this the correct way of preventing the UserForm or UserControl from scaling?
What are the correct dimensions (Weight and Width) for the UserFrom or UserControl?
Thank you for the support on this,
Arthur Knoors
Autodesk Affiliations:
