NachitoMax
in reply to: JelteDeJong
Hi
Thanks for the reply. I get that bit and it would be great if there was docuemtnatino to support the customization of the FlatPattern.xml. for example, i dont want to use the default layer names, i need to use our own names with different colors. I am able to set that up in the .ini file but it doesnt do anything when exporting from a drawing.
So
is there any documentation on customizing the flatpattern.xml? in code, i can do it this way and name my layers & colors
Public Sub WriteSheetMetalDXF()
    ' Get the active document.  This assumes it is a part document.
    Dim oDoc As PartDocument
    Set oDoc = ThisApplication.ActiveDocument
    ' Get the DataIO object.
    Dim oDataIO As DataIO
    Set oDataIO = oDoc.ComponentDefinition.DataIO
    ' Build the string that defines the format of the DXF file.
    Dim sOut As String
    sOut = "FLAT PATTERN DXF?" & _
            "AcadVersion=R12" & _
            "&OuterProfileLayer=CUT" & _
            "&OuterProfileLayerColor=255;0;0" & _
            "&BendUpLayer=BENDUP" & _
            "&BendUPLayerColor=0;255;0" & _
            "&BendDownLayer=BENDDOWN" & _
            "&BendDownLayerColor=0;255;0" & _
            "&InteriorProfilesLayer=INNER" & _
            "&InteriorProfilesLayerColor=255;0;127" & _
            "&TangentLayer=EXTENTS" & _
            "&TangentLayerColor=0;0;255"
    ' Create the DXF file.
    oDataIO.WriteDataToFile sOut, "C:\temp\flat2.dxf"
End Sub
Nacho
Automation & Design Engineer
Inventor automation Programmer (C#, VB.Net / iLogic)
Furniture, Sheet Metal, Structural, Metal fab, Tradeshow, Fabrication, CNC
