in reply to: JelteDeJong
Hey
in that dialog, i can only change linetypes. I accessed the layers by Right Clicking the flat pattern at part level, selecting Save Copy As, then updating layers. It works fine whgen exporting from part level but i need the same results from drawing level export. I did select the .ini file a created but it didnt do anything.
A code method is also good
I need to do this from drawing level because i need to adda bunch oftext from iproperties which i cant do when exporting from part level
thanks
