JelteDeJong
in reply to: NachitoMax
goto "Save copy as"
Set "Save as type" to "Dxf"
and select "Options..."
Check "Customize DWG/DXF" There will be a standard file wich you can change like you want. here you can set the layer names and that stuff.
finish and save.
Jelte de Jong
Blog: hjalte.nl - github.com
