NachitoMax
1336 Views, 4 Replies
Drawing - Export layers
Hey
In much the same way we can change the layers in code when exporting a flat pattern to a DXF, can we do the same from a drawing so that the exported dxf has the layers required instead of the generic layers? Either code or built in method would suffice as long as the exported flat pattern in the dxf isnt all on Visible (ISO)
cheers
Nacho
Automation & Design Engineer
Inventor automation Programmer (C#, VB.Net / iLogic)
Furniture, Sheet Metal, Structural, Metal fab, Tradeshow, Fabrication, CNC
