10-31-2019
06:33 AM
- Mute
- Permalink
- Report
10-31-2019
06:33 AM
Private Sub m_AppEvents_OnActivateDocument(ByVal DocumentObject As Inventor._Document, _
ByVal BeforeOrAfter As Inventor.EventTimingEnum, _
ByVal Context As Inventor.NameValueMap, _
ByRef HandlingCode As Inventor.HandlingCodeEnum) Handles m_AppEvents.OnActivateDocument
If BeforeOrAfter <> EventTimingEnum.kAfter Then
Exit Sub
End If
Dim odoc As Inventor.Document
odoc = g_inventorApplication.ActiveEditDocument
Dim eDocumentType As DocumentTypeEnum = odoc.DocumentType
Dim chb As CheckBox
Dim sDocumentType As String = "Unknown"
Select Case eDocumentType
Case DocumentTypeEnum.kAssemblyDocumentObject
For Each a As Control In oform.GroupBox1.Controls
If TypeOf a Is Windows.Forms.TextBox Then
a.Text = Nothing
End If
Next
Dim odef As AssemblyComponentDefinition = odoc.componentdefinition
Dim occ As ComponentOccurrence
For Each occ In odef.Occurrences
If TypeOf occ.Definition Is AssemblyComponentDefinition Then
' oForm.ComboBox1.Items.Add(occ.Name)
End If
Next
oform.TextBox1.Text = odef.Parameters.UserParameters.Item("height").Value * 10
oform.TextBox2.Text = odef.Parameters.UserParameters.Item("width").Value * 10
oform.TextBox3.Text = odef.Parameters.UserParameters.Item("depth").Value * 10
oform.TextBox4.Text = odef.Parameters.UserParameters.Item("front_bolt_qty").Value
oform.TextBox5.Text = odef.Parameters.UserParameters.Item("front_bolt_distance").Value * 10
oform.TextBox6.Text = odef.Parameters.UserParameters.Item("top_bottom_bolt_qty").Value
oform.TextBox7.Text = odef.Parameters.UserParameters.Item("top_bottom_bolt_distance").Value * 10
oform.GroupBox1.Text = odoc.PropertySets.Item("Design Tracking Properties").Item("Description").Value
For idx = 1 To oform.GroupBox1.Controls.Count
chb = oform.GroupBox1.Controls.Item(idx)
If odoc.PropertySets.Item("Inventor User Defined Properties").Item(oform.GroupBox1.Controls.Item(idx).Text).Value = "1" Then
chb.Checked = 1
Else
chb.Checked = 0
End If
Next
' sDocumentType = "Assembly Document"
' oForm.ComboBox1.Items.Clear()
' oForm.TextBox1.Text = ""
Case DocumentTypeEnum.kPartDocumentObject
sDocumentType = "Part Document"
Dim opdef As PartComponentDefinition = odoc.componentdefinition
a.Text = Nothing
End If
Next
chb.Checked = 1
Else
chb.Checked = 0
End If
Next
oform.TextBox1.Text = opdef.Parameters.UserParameters.Item("height").Value * 10
oform.TextBox2.Text = opdef.Parameters.UserParameters.Item("width").Value * 10
oform.TextBox3.Text = opdef.Parameters.UserParameters.Item("depth").Value * 10
oform.TextBox4.Text = opdef.Parameters.UserParameters.Item("front_bolt_qty").Value
oform.TextBox5.Text = opdef.Parameters.UserParameters.Item("front_bolt_distance").Value * 10
oform.TextBox6.Text = opdef.Parameters.UserParameters.Item("top_bottom_bolt_qty").Value
oform.TextBox7.Text = opdef.Parameters.UserParameters.Item("top_bottom_bolt_distance").Value * 10
End Select
End Sub
