10-28-2019
12:21 PM
- Mute
- Permalink
- Report
10-28-2019
12:21 PM
you could try the following:
Dim splitChar As String = ","
Dim keyLine As String
Dim valLine As String
Using reader As New IO.StreamReader("c:\temp\test.csv", Text.Encoding.Default)
keyLine = reader.ReadLine()
valLine = reader.ReadLine()
End Using
Dim keys As String() = keyLine.Split(splitChar)
Dim vals As String() = valLine.Split(splitChar)
Dim csvData As Dictionary(Of String, String) = New Dictionary(Of String, String)()
For i = 0 To keys.Count - 1
csvData.Add(keys(i), vals(i))
Next
For Each item As KeyValuePair(Of String, String) In csvData
MsgBox(item.Key & ": " & item.Value)
NextThis will fail if the number of key and values are not the same. If you have control over how the csv file is made i would advice you to setup different. its better tou put a key/value pair on each line. like this:
length,1000
Width,500
Its more easy to read and the following iLogic rule will not fail enterly when a line is not correct.
Dim line As String = reader.ReadLine
Do While (Not line Is Nothing)
Try
Dim splittedLine As String() = line.Split(splitChar)
csvData.Add(splittedLine(0), splittedLine(1))
Catch ex As Exception
MsgBox("Could not add data from line: " & line)
End Try
line = reader.ReadLine
Loop
End Using
Next
Jelte de Jong
Blog: hjalte.nl - github.com
