- Mute
- Permalink
- Report
I am trying to export dxf files through the API with the FeatureProfilesLayer color set to yellow but cannot seem to get the syntax correct or maybe missing something else. In any case it is not working. Can somebody show the correct format or point me in the right direction? Code below...
sOut = "FLAT PATTERN DXF?AcadVersion=R12&" &
"OuterProfileLayer=CUT&" &
"InteriorProfilesLayer=CUT&" &
"FeatureProfilesLayer=ETCH&" &
"FeatureProfilesLayerColor=255;255;0" &
"InvisibleLayers=IV_ARC_CENTERS;IV_TOOL_CENTER;IV_TOOL_CENTER_DOWN;IV_UNCONSUMED_SKETCHES"
- Mute
- Permalink
- Report
I set a color for our ETCH layer and a few other things with mine:
Dim sOut As String
sOut = "FLAT PATTERN DXF?AcadVersion=2010&" &
"OuterProfileLayer=0&" &
"InteriorProfilesLayer=0&" &
"BendUpLayerColor=255;255;0&" &
"BendUpLayerLineType=37641&" &
"BendDownLayerColor=255;255;0" &
"BendDownLayerLineType=37641&" &
"BendUpLayer=Etch&" &
"BendDownLayer=Etch&" &
"BendLayer=Etch&" &
"FeatureProfilesUpLayer=Etch&" &
"FeatureProfilesUpLayerColor=255;255;0&" &
"FeatureProfilesUpLayerLineType=37641&" &
"FeatureProfilesDownLayer=Etch&" &
"FeatureProfilesDownLayerColor=255;255;0&" &
"FeatureProfilesDownLayerLineType=37641&" &
"UnconsumedSketchesLayer=Etch&" &
"UnconsumedSketchesLayerColor=255;255;0&" &
"UnconsumedSketchesLayerLineType=37641&" &
"InvisibleLayers=IV_ARC_CENTERS;IV_TANGENT" &
"SimplifySplines=False"
- Mute
- Permalink
- Report
I was missing an ampersand within the quotes on this line... "FeatureProfilesLayerColor=255;255;0" &
And needed to add "FeatureProfilesUpLayerColor=255;255;0&" & "FeatureProfilesDownLayerColor=255;255;0&" &
Thank you very much for your post!!!
- Mute
- Permalink
- Report
No problem.
Saw your post and remembered doing this, having the same problem, and think the answer was kinda dumb
Glad i knew where it was.
