felix.cortes5K3Y2
699 Views, 3 Replies
iLogic to Change Drawing's Part List Style
Hi Forum,
I have two different Part List Styles that I use on my drawings and I am trying to write a code to switch in between them. Lets say I have a Part List Style named as "Style One" and "Style Two". Here's what I got so far:
Dim oDrawDoc As DrawingDocument = ThisApplication.ActiveDocument
Dim oPartsList As PartsList = oDrawDoc.ActiveSheet.PartsLists(1)
oPartsList.Style() = "Style Two"
This code doesn't seem to work. Anyone have an idea?
- Felix Cortes
rhasell
in reply to: felix.cortes5K3Y2
Hi
Try this.
Once you have got it working, expand the code to include a multivalue list, allowing a wider selection.
oDrawDoc = ThisApplication.ActiveDocument
Dim oPartsList1 As PartsList
oPartsList1 = oDrawDoc.ActiveSheet.PartsLists.Item(1)
			oPartsList1.Style = oDrawDoc.StylesManager.PartsListStyles.Item("Style Two")
Reg
2025.2
felix.cortes5K3Y2
in reply to: rhasell
Thanks rhasell
How could I add a multilist? Seems like iLogic only has a limited input boxes
rhasell
Hi
Here is a copy of my code.
You will need to create a parts list style for each configuration.
The code is not triggered, so it has to be run after a change is made.
'Apply Parts List Filter
'Created 17/07/2017
'PRTL = Parts List
'Reg Hasell
Sub Main
	'Choose the parts list, 1 is the first one placed.
	oPRTL = InputBox("Choose the Parts List", "Parts List Filter", "1")
	'Create a multi value list if not there.
	Call Create_Params()
	Call ApplyFilter(oPRTL)
End Sub
Sub Create_Params()
	' Get the UserParameters collection
	Dim userParams As UserParameters
	userParams = ThisDoc.Document.Parameters.UserParameters
	'check for parameter and create if not found
	Try
		oPartslist = Parameter("Parts_List")
	Catch
		'multi-value text parameter
		userParams.AddByValue("Parts_List", "ALL", UnitsTypeEnum.kTextUnits)
		'Option of two types, this is also present in the Global Form
		MultiValue.SetList("Parts_List", "ALL", "No_Fasteners", "Fasteners_Only")
	End Try
	Parameter.Param("Parts_List").IsKey​ = True
End Sub
Sub ApplyFilter(oPRTL)
	On Error Resume Next
	oPartsList1 = oDrawDoc.ActiveSheet.PartsLists.Item(oPRTL)
	If oPartslist = "ALL"
		oPartsList1.Style = oDrawDoc.StylesManager.PartsListStyles.Item("Parts List")
	Else If oPartslist = "No_Fasteners"
	oPartsList1.Style = oDrawDoc.StylesManager.PartsListStyles.Item("Parts List-NoFasteners")
	Else If oPartslist = "Fasteners_Only"
	oPartsList1.Style = oDrawDoc.StylesManager.PartsListStyles.Item("Parts List-Fasteners")
	End If
End Sub
Reg
2025.2
