- Mute
- Permalink
- Report
This will guide you in the correct direction i think!
Public Sub main() Dim a As Application Set a = ThisApplication Dim b As DrawingDocument Set b = a.ActiveDocument Dim c As Balloon Set c = b.ActiveSheet.Balloons.Item(1) Dim v As DrawingView Set v = c.ParentView MsgBox v.Parent.Name End Sub
Please let me know if you need further assistance....
Arthur Knoors
Autodesk Affiliations:
