Could you please mark the solution as solved and not the reply to the solution, as it is usual.
For administration reasons this is the usual way of doing it.
Thank you for your understanding.
Hope that you will mark the solution in future too,
Best regards,
Arthur Knoors
Autodesk Affiliations:
