Take a look at the flat-pattern orientation in the ipt file!
by:
select Flat-pattern
Right Mouse Click
Go to flat pattern.
Change the orientation to the XYZ axis as needed to display correctly. (This could have a rotation!!!)
Arthur Knoors
Autodesk Affiliations:
