iva.btblan
431 Views, 3 Replies
Planning - Rule Doesn't Work!
Why doesn't the rule work?
Different dimensions.
Rule does not work.
How to solve it?
Can someone help me?
Take a look at the flat-pattern orientation in the ipt file!
by:
select Flat-pattern
Right Mouse Click
Go to flat pattern.
Change the orientation to the XYZ axis as needed to display correctly. (This could have a rotation!!!)
Arthur Knoors
Autodesk Affiliations:
Excellent!   Thanks!
Could you please mark the solution as solved and not the reply to the solution, as it is usual.
For administration reasons this is the usual way of doing it.
Thank you for your understanding.
Hope that you will mark the solution in future too,
Best regards,
Arthur Knoors
