10-18-2019
05:46 AM
- Mute
- Permalink
- Report
10-18-2019
05:46 AM
This should output the member files (the same as right clicking on the members in the browser and choosing Generate Files) however it does't work... so that is why the break link function does not work.
I'm not sure why this is not working in iAssemblies, there might simply be something else we have to do first, but I'm not sure.
Dim oParent As iAssemblyFactory oParent = ThisDoc.Document.ComponentDefinition.iAssemblyFactory Dim oRow As iAssemblyTableRow For Each oRow In oParent.TableRows oParent.CreateMember(oRow) Next
In any case, here is an example that gets the iAssembly cache folder from the factory file, and opens each assembly, then checks to make sure it is an iAssembly member and then breaks the link, saves and closes
Dim oParent As iAssemblyFactory oParent = ThisDoc.Document.ComponentDefinition.iAssemblyFactory Dim oRow As iAssemblyTableRow Dim oDoc As AssemblyDocument Dim oDef As AssemblyComponentDefinition oMemberFolder = oParent.MemberCacheDir Dim fileEntries As String() = System.IO.Directory.GetFiles(oMemberFolder,"*.iam") Dim fileName As String For Each fileName In fileEntries oDoc = ThisApplication.Documents.Open(fileName, False) oDef = oDoc.ComponentDefinition If oDef.IsiAssemblyMember Then oMember = oDef.iAssemblyMember oMember.BreakLinkToFactory oDoc.save End If oDoc.close Next
I hope this helps.
Curtis
