j.haggenjos
655 Views, 7 Replies
Shared Variable of a structure losing structure "Type"
Hello all,
I'm in the process of coding my first iLogic project. I'm having an issue with a shared variable
I have one rule reading data from a CSV file and puting them into a customer parameter Structure.
Public Structure CustomParam
	Public n As Integer
	Public Name() As String
	Public Values As ArrayList
End Structure
	Dim oCustomParams As ArrayList
	oCustomParams = ReadParam(oPath)
	SharedVariable("oCustomParams") = oCustomParams
	Dim oCustomParam As CustomParam
	oCustomParam = ReadParam(oPath_single)
	SharedVariable("oCustomParam") = oCustomParam
The data is transfered to other rules correctly and I can access all the data. Both a single variable and an ArrayList of variables work. My issue is that I can't "call"  the structure type anymore.
Sub MySub (oCustomParam As CustomParam)
End Sub
Sub MySub (oCustomParam)
End Sub
The first case will return a "Specified cast is not valid."
Not specifying the argument type will solve the issue. However, I would like if possible to specify the argument as a "CustomParam".
Is there any way to achieve this? Maybe a Structure is not the proper way to handle this. I don't have much coding experience so I may be looking at this wrong.
Thank you in advance for your time and answers!
