- Mute
- Permalink
- Report
I'm trying to figure out how to create an empty 2D array in iLogic and then fill the array like a table. The VBA equivalent would go something like this:
Dim MyArray(0 To 1, 0 To 1) As String
MyArray(0, 0) = "00"
MyArray(0, 1) = "01"
MyArray(1, 1) = "11"
MyArray(1, 0) = "10"
MsgBox MyArray(0, 1) 'outputs string "01"
- Mute
- Permalink
- Report
The ilogic/vb.net equivalent:
Dim myArray(1,1) As String myArray(0,0) = "00" myArray(0,1) = "01" myArray(1,0) = "10" myArray(1,1) = "11" MsgBox( myArray(0, 1)) 'outputs string "01"
Jelte de Jong
Blog: hjalte.nl - github.com
- Mute
- Permalink
- Report
Thank you for your reply. I was actually able to get my original code (see below) to work. I identified the wrong problem. The problem wasn't the array, it was putting that array in a custom table (see line 23). My desired output is attached (see screen shot
Sub Main
Dim oDrawDoc As DrawingDocument
Dim oSheet As Sheet
Dim oTitles() As String
Dim oContents() As String
Dim oCustomTable As CustomTable
oDrawDoc = ThisDoc.Document
oSheet = oDrawDoc.ActiveSheet
' oTitles = {"DWG TYPE", "FAB STATUS", "DRAWING NUMBER", "REV. NO.", "DESCRIPTION" }
oTitles = {"DWG TYPE", "FAB STATUS"}
Dim MyArray(0 To 1, 0 To 1) As Object
MsgBox("myarray(0,0) = " & myarray(0,0))
' oCustomTable = oPSheet.CustomTables.Add("PRINT REQUEST FORM", ThisApplication.TransientGeometry.CreatePoint2d(15, 15), 3, 4, oTitles, oContents)
oCustomTable = oSheet.CustomTables.Add("Sample Table", ThisApplication.TransientGeometry.CreatePoint2d(15, 15), 2, 2, oTitles,MyArray) '''here's my problem line of code
end sub
- Mute
- Permalink
- Report
it's maby a bit strange but you dont need a multi dimension array. The help states:
Optional input String array that specifies the contents of the table. The number of Strings must match the number of cells in the table, else an error will occur. This array of String is used to sequentially populate each row of the table
try the following array
Dim myArray(3) As String myArray(0) = "00" myArray(1) = "01" myArray(2) = "10" myArray(3) = "11"
Jelte de Jong
- Mute
- Permalink
- Report
I think I see what you're saying. It's a little counter intuitive. A multidimensional array is NOT required. The TOTAL number of cells must match the TOTAL number of data cells excluding the title cells. Thank you for clarifying that.
