- Mute
- Permalink
- Report
I'm building an assembly through code and I'm able to add constraints when the planes are at the top level of the sub assembly but not when its as plane in an occurrence of that sub assembly.
Example: Trying to add mate constraint to "Part1Plane1" & "AsmPart1Plane1" from Main Assembly
Main Assembly
-Part1
--"Part1Plane1"
-Assembly1
--AsmPart1
---"AsmPart1Plane1"
- Mute
- Permalink
- Report
Hi @aspecchio
In order to use a plane that is not in a first level component you have to create a proxy for that plane and use that.
See code below. You can use the function provided to create a proxy for a plane how deep down you want by passing an agrument as a string of the "path" to the occurrence containing the plane, separated by "¤" and one argument for the name of the plane.
If you're not writing in iLogic, you cant use "ThisDoc.Document" for the main assembly, so that has to be changed to ActiveDocument or whatever in that case...
In the code below it is PlaneProx you should use to create the constraint.
Sub Main Dim PlaneProx As WorkPlaneProxy = CreatePlaneProxy("Assembly1¤AsmPart1", "AsmPart1Plane1") End Sub Function CreatePlaneProxy(occString As String, oWPName As String) As Object Dim occList As New List(Of ComponentOccurrence) Dim occArr() As String = occString.Split("¤") For i = 0 To occArr.Length - 1 If i = 0 Then occList.Add(ThisDoc.Document.ComponentDefinition.Occurrences.ItemByName(occArr(i))) Else occList.Add(occList.Item(i - 1).Definition.Occurrences.ItemByName(occArr(i))) End If Next Dim oProx As Object For i = occList.Count - 1 To 0 Step -1 If i = occList.Count - 1 Call occList(i).CreateGeometryProxy(occList(i).Definition.WorkPlanes.Item(oWPName), oProx) Else Call occList(i).CreateGeometryProxy(oProx, oProx) End If Next Return oProx End Function
Hope this helps!
Jhoel Forshav
Download my free Inventor Addin - Hole Projector
LinkedIn | Ideas | Contributions | Blog posts | Website
