- Mute
- Permalink
- Report
I have this code .. I keep getting an error .. that I want the code to
do is to cleal override the component in the assembly on all view... I have a code that do the same for part... that work ... I have a code the can add an colour to the component or part ... but I like to make the code needed to remove the colour again after add them to the part and assembly ... only thing that I can not get to work jet is the assembly clearsoverride.. see the code I have so far below
Dim oAsmCompDef 'As AssemblyComponentDefinition
oAsmCompDef = ThisApplication.ActiveDocument.ComponentDefinition
Dim oViewReps As DesignViewRepresentations
oViewReps = oAsmCompDef.RepresentationsManager.DesignViewRepresentations
'define view rep
Dim oViewRep As DesignViewRepresentation
Dim NumberOfView = oViewReps.Count
' get Manager of Representations
Dim dViewRepMgr As RepresentationsManager
dViewRepMgr = oAsmCompDef.RepresentationsManager
'Get active Representation View
Dim dViewRep As DesignViewRepresentation
dViewRep = dViewRepMgr.ActiveDesignViewRepresentation
For i = 1 To NumberOfView
If iProperties.Value("Custom", "Surface") = "Raw" Or iProperties.Value("Custom", "Surface") = "Galv." Or iProperties.Value("Custom", "Surface") = "Colour 1" Or iProperties.Value("Custom", "Surface") = "Colour 2" Or iProperties.Value("Custom", "Surface") = "RAL 5003" Or iProperties.Value("Custom", "Surface") = "RAL 9010" Or iProperties.Value("Custom", "Surface") = "RAL 1028" Or iProperties.Value("Custom", "Surface") = "RAL 9005" Or iProperties.Value("Custom", "Surface") = "EG-Galv" Or iProperties.Value("Custom", "Surface") = "HDG-Galv" Then
oViewReps.Item(i).Activate
End If
Dim oAsmDoc As AssemblyDocument
oAsmDoc = ThisDoc.Document
Dim oAsmCompDef As AssemblyComponentDefinition
oAsmCompDef = oAsmDoc.ComponentDefinition
Dim oOccurrence As ComponentOccurrence
For Each oOccurrence In oAsmCompDef.Occurrences
oAsmCompDef.ClearAppearanceOverrides(oOccurrence.name)
iLogicVb.UpdateWhenDone = True
Next
Next
- Mute
- Permalink
- Report
Actually, method AssemblyComponentDefinition.ClearAppearanceOverrides( [AppearanceOverrideObjects] As Variant ) would accept input parameter as object collection. Try below changes in your iLogic code.
'define view rep
End If
Dim objColl As ObjectCollection
objColl = ThisApplication.TransientObjects.CreateObjectCollection
Call objColl.Add(oOccurrence)
Next
oAsmCompDef.ClearAppearanceOverrides(objColl)
Next
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
Autodesk Developer Network
- Mute
- Permalink
- Report
It almost work I did have to delete 2 line of the code... but after that it look like it will work
'define view rep
End If
Next
Next
