in reply to: bradeneuropeArthur
There are two custom variable: (I am hungarian, and i use hungarian expression.
In the picture you can se in red falg.
06. Pót alkatrész / Kopó alkatrész (P/K)
 In the picture you can se in blue falg.
09. Rajz A/H/Ö/K
When I realise these custom part value are wrong, I would like to modify from drowing. This rule rewrite these value from drowing to part or assembly. I dont't have to open the part.
I would like to use this rule to active sheet. When this rule work well, then I would like to upgrade to block rewrite. I designate more drawings and this rule upgrade these part or assembly with the same value.
