Preset all addins to Demand Load.  Won't load until something needs it too.  Much of Inventor startup time is not the add-in's anyway.
Can you run multiple Inventors, yes, if you start them via your code.  I have a VB.Net exe that does NOT run as an Inventor Add-IN it uses this to get Inventor:
    Public Function GetInventorApplication() As Inventor.Application
        If invApp Is Nothing Then
            If invAppCollection IsNot Nothing Then
                If invAppCollection.Count > 0 Then
                    For i As Integer = invAppCollection.Count - 1 To 0 Step -1
                        If invAppCollection(i) IsNot Nothing Then
                            invApp = invAppCollection(i)
                            Exit For
                        Else
                            invAppCollection.RemoveAt(i)
                        End If
                    Next
                End If
            End If
            Try
                invApp = Marshal.GetActiveObject("Inventor.Application
            Catch ex As Exception
                Try
                    Dim invAppType As Type = GetTypeFromProgID("Inventor.Application")
                    invApp = CreateInstance(invAppType)
                    invApp.Visible = True
                    'counter the app
                    Dim counter As Integer = 0
                    Do While invApp.Ready = False
                        counter += 1
                        Debug.Print(counter)
                        If counter > 1000 Then
                            Exit Do
                        End If
                    Loop
                    For Each addIn As ApplicationAddIn In invApp.ApplicationAddIns
                        Try
                            If addIn.LoadBehavior = AddInLoadBehaviorEnum.kLoadImmediately Then
                                addIn.Activate()
                            End If
                        Catch exAddIn As Exception
                            'skip it
                        End Try
                    Next
                    invAppWasStarted = True
                Catch ex2 As Exception
                    MsgBox("Unable to get or start Inventor" & vbCr & ex2.ToString, MsgBoxStyle.SystemModal)
                End Try
            End Try
        End If
        Try
            Dim dcountTest As Integer = invApp.Documents.Count
            invApp = Nothing
        End Try
        Return invAp
You can use the application collection to separate which Inventor is doing what that way.  Note my code did not Add the new inventor to the collection, you will need to do that.
Some random thoughts:
Unless your running a KickA machine running multiple Inventor's may not be a good idea.  I would also like to add another point, if Inventor keeps crashing, your documents may need to be Migrated with Total Rebuild to update their versions to the latest versions.  Inventor can, but does not like running multiple version assembly files, and tends to get stupid.  Closing all documents should allow inventor time to purge its memory sponge, but I agree it still tends to leak memory (if not hemorrhage).  The Task scheduler puts a clock on the inventor applications and attempts retry 3 times.  It also performs a max file count before closing Inventor and starting a new one.  I've experimented with this.  All is well unless you get Vault involved.  Finally, Inventor handles System.Threading.Tasks.Parallel.For, meaning you can get it to run multiple tasks on multiple threads at once.  This is good when using tasks that look up lists, and such, not so good when adding to the database (use SyncLock or die!)  So you may be able to have multiple documents process at once if you code it right.
jvj
