in reply to: JamieVJohnson2
So the answer is you can't? I need to be able to switch between the two depending on what the user wants on every job.
Thanks for your thoughts.
Option 1 won't work with Vault
Option 2 will bugger up CC
Option 3 sounds like a botch
If under the same CC family table I have both stainless and zinc is it possible to switch between the two using iLogic?
The last resort option is to save all the bolts I need to a normal folder on Vault, but the problem is that I'm then adding identical copies of things to vault when I'd like to keep everything as CC.
