09-30-2019
09:02 AM
- Mute
- Permalink
- Report
09-30-2019
09:02 AM
Option 1. Replace All Components.
This would require you to get the necessary replacement files OUT of the content center and stored locally first, say in a dummy assembly.
Option 2. Modify the family to change its material, then update parts. This is a permanent change, so if you plan to use material A then material B, and back, this would not be the best idea.
Option 3. Override all parts materials using BOM drill down method, this would require you to fool Inventor into thinking the Content Center Folder is just another design folder (modify IPJ), and all the files would need to be read-write.
jvj
