HideoYamada
in reply to: HideoYamada
Inventor seems to read the files in the following directory to determine which Add-In to load or not.
C:\Users\<User Name>\AppData\Roaming\Autodesk\Inventor 2020\Addins
And Inventor looks like accessing to this directory only when it's booting or using AddIn Manager.
You can rename the directory 'Addins' to another even if Inventor is running.
Once you prepare the configuration set which loads minimum add-ins, you can switch the configuration to it before booting remote Inventor by renaming the name of 'Addins' directory.
Keep mind that this technique is tricky and there is a risk of unexpected problems.
However, I think it is worth trying.
Freeradical
 Hideo Yamada
Freeradical
 Hideo Yamada
https://www.freeradical.jp
