- Mute
- Permalink
- Report
@Cadkunde.nl wrote:Oh btw, overlooked your tip on running invisible. I'm doing that. thx.
Tips to run it faster are appreciated. But its the inventor client that runs out of mem, not script.
Sometimes Inventor crashes when it is visible and operated from outside.
(The effect of running invisible has less effect on speed.)
If the crash doesn't occur when you operate same things manually, the problem is not caused by memory.
What version of Inventor are you using?
As you said, older version must be restarted after opening large assy, but I don't care in last few versions.
If booting time is still a problem and the operation doesn't save any docs, I recommend that prepare new remote Inventor process during the other remote Inventor is processing.
Freeradical
Hideo Yamada
