Sergio.D.Suárez
Hi, try the following ilogic rule. I attach a sample file
In this rule I show you another more secure access to the parameter.
Dim doc As PartDocument= ThisDoc.Document
Dim oCD As ComponentDefinition = doc.ComponentDefinition
Dim oType As String = oCD.parameters("Type").value
If oType = "A" Then Feature.IsActive("Type B") = False
If oType = "B" Then Feature.IsActive("Type B") = True
iLogicVb.UpdateWhenDone = True
Parameter.UpdateAfterChange = True
I hope this helps with your problem. Regards
Please accept as solution and give likes if applicable.
I am attaching my Upwork profile for specific queries.
Sergio Daniel Suarez
Mechanical Designer
| Upwork Profile | LinkedIn
