in reply to: JamieVJohnson2
 I was afraid there is no easy way for this. I actually don't understand using vectors in inventor and translating from 3dmodel space to  2d sketch space,I always get some kind an error.@JamieVJohnson2 can i trouble you to finish this code with the method you explained in the reply if it is not too much trouble?????
Dim partDoc As PartDocument
partDoc = ThisApplication.ActiveDocument
Dim partDef As Inventor.PartComponentDefinition
partDef = partDoc.ComponentDefinition
'set a reference to the transient geometry collection.
Dim oTransGeom As TransientGeometry
oTransGeom = ThisApplication.TransientGeometry
' Create a new sketch.
Dim oSketch As PlanarSketch
oSketch = partDef.Sketches.Add(partDef.WorkPlanes.Item(1), False)
oSketch.Edit
Dim oOriginSketchPoint As SketchPoint = oSketch.AddByProjectingEntity(partDef.WorkPoints.Item(1))
oline = oSketch.SketchLines.AddByTwoPoints(oOriginSketchPoint, ThisApplication.TransientGeometry.CreatePoint2d(- 100, - 100))
