- Mute
- Permalink
- Report
Adding / projecting back view
Hey
I have a method that is adding a base view to a sheet. I need to add the opposite / back view of the current view either as a separate view or projected but cant figure it out.
Anyone know a way of doing that?
Nacho
Automation & Design Engineer
Inventor automation Programmer (C#, VB.Net / iLogic)
Furniture, Sheet Metal, Structural, Metal fab, Tradeshow, Fabrication, CNC
- Mute
- Permalink
- Report
this iLogic rule uses the first DrawingView on the sheet to create the back view (and rightview but that will be deleted automaticaly.)
Dim doc As DrawingDocument = ThisApplication.ActiveDocument Dim oSheet As Sheet = doc.ActiveSheet Dim baseView As DrawingView = oSheet.DrawingViews.Item(1) Dim oTG As TransientGeometry = ThisApplication.TransientGeometry Dim baseViewPosition As Point2d = baseView.Position Dim BaseViewWidth As Double = baseView.Width Dim rightViewPosition As Point2d = oTG.CreatePoint2d(baseViewPosition.X + 1 + BaseViewWidth / 2, baseViewPosition.Y) Dim backViewPosition As Point2d = oTG.CreatePoint2d(baseViewPosition.X + 1 + BaseViewWidth, baseViewPosition.Y) Dim drawingViewStyle As DrawingViewStyleEnum = DrawingViewStyleEnum.kFromBaseDrawingViewStyle Dim rightView As DrawingView = oSheet.DrawingViews.AddProjectedView(baseView, rightViewPosition, drawingViewStyle) Dim backView As DrawingView = oSheet.DrawingViews.AddProjectedView(rightView, backViewPosition, drawingViewStyle) 'the right view was created to create the back view but is not what you asked for, therfor it can be deleted rightView.Delete() ' this line is not mandatory but make makes sure that the views stay aligned backView.Align(baseView, DrawingViewAlignmentEnum.kHorizontalViewAlignment)
Jelte de Jong
Blog: hjalte.nl - github.com
- Mute
- Permalink
- Report
I tried another way. This code will create an opposite view directly.
Option Explicit
Sub CreateOppositeView()
Dim oDrawingDoc As DrawingDocument
Set oDrawingDoc = ThisApplication.ActiveDocument
Dim oSourceView As DrawingView
Set oSourceView = oDrawingDoc.ActiveSheet.DrawingViews(1)
' Document
Dim oSourceDoc As Document
Set oSourceDoc = oSourceView.ReferencedDocumentDescriptor.ReferencedDocument
' Position
Dim oViewPosition As Point2d
Set oViewPosition = oSourceView.Position.Copy
oViewPosition.X = oViewPosition.X + oSourceView.Width + 1
' Scale
Dim viewScale As Double
viewScale = oSourceView.Scale
' ViewStyle
Dim viewStyle As DrawingViewStyleEnum
viewStyle = oSourceView.viewStyle
' ModelViewName
Dim modelViewName As String
modelViewName = oSourceView.ActiveDesignViewRepresentation
' Camera
Dim oCamera As Camera
Set oCamera = ThisApplication.TransientObjects.CreateCamera
oCamera.Eye = GetOppositeEyePoint(oSourceView.Camera)
oCamera.Target = oSourceView.Camera.Target
oCamera.UpVector = oSourceView.Camera.UpVector
' Create new DrawingView
Dim oNewDrawingView As DrawingView
Set oNewDrawingView = oDrawingDoc.ActiveSheet.DrawingViews.AddBaseView(oSourceDoc, oViewPosition, viewScale, kArbitraryViewOrientation, viewStyle, modelViewName, oCamera)
End Sub
Function GetOppositeEyePoint(oCamera As Camera) As Point
Dim X As Double
Dim Y As Double
Dim Z As Double
X = oCamera.Target.X * 2 - oCamera.Eye.X
Y = oCamera.Target.Y * 2 - oCamera.Eye.Y
Z = oCamera.Target.Z * 2 - oCamera.Eye.Z
Set GetOppositeEyePoint = ThisApplication.TransientGeometry.CreatePoint(X, Y, Z)
End Function=====
Freeradical
Hideo Yamada
