09-20-2019
01:29 PM
- Mute
- Permalink
- Report
09-20-2019
01:29 PM
Hi Brent,
The .cfg file isn't something you are actually making. It's a format file that shows inventor how you want the data imported/exported to the reports.
At the link above, you'll want to download the sample file pack for your version of Inventor. You might already have them from when you set up your Wire Library. Once downloaded, you'll need to locate the file "WireLibrary.cfg."
I don't know for sure if it will store in the same place, but mine is located under "Inventor 2019->Samples->en-US->autodesk_inventor_2019_samples_dlm->Models->Cable & Harness->Wire Library".
Once located, you can select the path to that file for your library export.
Let me know if I missed anything.
