09-17-2019
08:18 AM
- Mute
- Permalink
- Report
09-17-2019
08:18 AM
Do all custom iProperties require a string output?
I'm trying to set up a code where I can update an iProperty based on inputs. I modified the example code to update iProperties. The sub would be used with texts, bools, and numbers. I set the input as a variant but get errors if I pass anything other than a variant or string. What's the rules on iProps?
Public Sub CalliProp()
Dim docCurr As Document
Set docCurr = ThisApplication.ActiveDocument
Dim dblTest As Double
dblTest = 3.22222
Call UpdateCustomiProp(docCurr, "Woohah", dblTest)
End Sub
Public Sub UpdateCustomiProp(docDoc As Document, strPropTitle As String, varValue As Variant)
' Get the custom property set.
Dim psCustom As PropertySet
Set psCustom = docDoc.PropertySets.Item("Inventor User Defined Properties")
Dim propCurrent As Property
Set propCurrent = psCustom.Item(strPropTitle)
If Err.Number <> 0 Then
' Failed to get the property, which means it doesn't exist
' so we'll create it.
Call psCustom.Add(varValue, strPropTitle)
Else
' Got the property so update the value.
propCurrent.Value = varValue
End If
End Sub
