09-16-2019
02:33 AM
- Mute
- Permalink
- Report
09-16-2019
02:33 AM
Hi, it is not necessary that you have two parameters, you can have only one, and then with an ilogic load values according to this parameter. In the example of ilogic that I share I create a list with the values you mention.
Dim oValueList As New ArrayList Dim oValue As String If Wheel = "Single" Then oValueList.Add("Ø100") oValueList.Add("Ø400") oValue = InputListBox("select the appropriate diameter", oValueList, "Ø100", "Ilogic", "Available Selections") Else oValueList.Add("Ø100") oValueList.Add("Ø200") oValueList.Add("Ø300") oValueList.Add("Ø400") oValue = InputListBox("select the appropriate diameter", oValueList, "Ø100", "Ilogic", "Available Selections") End If
Maybe some similar approach can be useful, regards
Please accept as solution and give likes if applicable.
I am attaching my Upwork profile for specific queries.
Sergio Daniel Suarez
Mechanical Designer
| Upwork Profile | LinkedIn
