andrew.tom.reynolds
347 Views, 2 Replies
iLogic Drawing View Label Position not working with Flat Pattern views?
I'm using a few short lines of iLogic to update my flat pattern drawing views from a configurable model and I was wondering why i couldn't get it to work. Then I tested it on an assembly drawing and then on a drawing with the folded parts and it works fine. It seems that it doesn't work on views which are flat patterns!
The original info came from here: https://forums.autodesk.com/t5/inventor-customization/drawing-view-label-position-with-ilogic/m-p/64...
Can anyone help me with some alternative that will work with flat patterns, or is this a bug??
Dim oDoc As DrawingDocument
oDoc = ThisApplication.ActiveDocument
Dim oSheet As Sheet
oSheet = oDoc.ActiveSheet
Dim mDocQty As Double
Dim mDoc As Document
For Each oView As DrawingView In oSheet.DrawingViews
	mDoc = oView.ReferencedDocumentDescriptor.ReferencedDocument
	mDocQty = mDoc.PropertySets.Item("Inventor User Defined Properties").Item("QTY").Value
	wPoint = ThisApplication.TransientGeometry.CreatePoint2d(oView.Center.X, oView.Center.Y)
	oView.Label.Position = wPoint
	If mDocQty = 0 Then
		oView.Suppressed = True
	Else
		oView.Suppressed = False
	End If
Next
Thanks!
