- Mute
- Permalink
- Report
iLogic Drawing View Label Position not working with Flat Pattern views?
I'm using a few short lines of iLogic to update my flat pattern drawing views from a configurable model and I was wondering why i couldn't get it to work. Then I tested it on an assembly drawing and then on a drawing with the folded parts and it works fine. It seems that it doesn't work on views which are flat patterns!
The original info came from here: https://forums.autodesk.com/t5/inventor-customization/drawing-view-label-position-with-ilogic/m-p/64...
Can anyone help me with some alternative that will work with flat patterns, or is this a bug??
Dim oDoc As DrawingDocument
oDoc = ThisApplication.ActiveDocument
Dim oSheet As Sheet
oSheet = oDoc.ActiveSheet
Dim mDocQty As Double
Dim mDoc As Document
For Each oView As DrawingView In oSheet.DrawingViews
mDoc = oView.ReferencedDocumentDescriptor.ReferencedDocument
mDocQty = mDoc.PropertySets.Item("Inventor User Defined Properties").Item("QTY").Value
wPoint = ThisApplication.TransientGeometry.CreatePoint2d(oView.Center.X, oView.Center.Y)
oView.Label.Position = wPoint
If mDocQty = 0 Then
oView.Suppressed = True
Else
oView.Suppressed = False
End If
NextThanks!
- Mute
- Permalink
- Report
I tested the code and it works on flat pattern views for me. Given that the sheet metal part has a custom iProperty called "QTY". I'm running inventor 2020.
Are you saying that it works for a view of a folded sheetmetal part but not for the flat pattern view of the same part?
Jhoel Forshav
Download my free Inventor Addin - Hole Projector
LinkedIn | Ideas | Contributions | Blog posts | Website
- Mute
- Permalink
- Report
Hey sorry, in testing it again i've discovered that on the specific drawing sheet I was using it had the information as text on a sketch attached to the view, not using the view label.
I've tried it again on a fresh drawing and it's working fine... False alarm!
