JelteDeJong
i see that clutsa just answerd your question befor i could post my code. i will post it anyway because it's a bit more extensive but comes down to the same.
        Dim doc As DrawingDocument = ThisApplication.ActiveDocument
        Dim oSheet As Sheet = doc.ActiveSheet
        Dim oview As DrawingView = osheet.DrawingViews(1)
        'Dim dimension As GeneralDimension
        Dim oTg = ThisApplication.TransientGeometry
        For Each dimension As DrawingDimension In oSheet.DrawingDimensions
            Dim midPointText As Point2d = dimension.Text.Origin
            Dim midPointView = oview.Center
            Dim textHeight = 0.5
            Dim newX As Double
            Dim newY As Double
            Dim deltaX As Double = (oview.Width * 0.5) + 0.6
            Dim deltaY As Double = (oview.Height * 0.5) + 0.6
            If (midPointText.X > midPointView.X + oview.Width / 2) Then
                newX = midPointView.X + deltaX
                newY = midPointView.Y
            End If
            If (midPointText.X < midPointView.X - oview.Width / 2) Then
                newX = midPointView.X - deltaX - textHeight
            End If
            If (midPointText.Y > midPointView.Y + oview.Height / 2) Then
                newY = midPointView.Y + deltaY + textHeight
            End If
            If (midPointText.Y < midPointView.Y - oview.Height / 2) Then
                newY = midPointView.Y - deltaY
            End If
            Dim newMidPoint As Point2d = oTg.CreatePoint2d(newX, newY)
            dimension.Text.Origin = newMidPoint
        Next
Jelte de Jong
Blog: hjalte.nl - github.com
