09-09-2019
04:26 AM
- Mute
- Permalink
- Report
09-09-2019
04:26 AM
@Anonymous When running a rule from the iLogic IDE you need to have a Main Sub and then call your other Sub from within the Main or just put your code in the Main Sub. Also the "Set" command is an invalid command in the iLogic IDE so those just need to be removed. Try this
Sub Main() Door_Corners() End Sub Sub Door_Corners() Dim oDoc As PartDocument oDoc = ThisApplication.ActiveDocument Dim oDef As PartComponentDefinition oDef = oDoc.ComponentDefinition Dim oPoint As Vertex oPoint = ThisApplication.CommandManager.Pick(kPartVertexFilter, "Right Side") Dim wp1 As WorkPoint wp1 = oDef.WorkPoints.AddByPoint(oPoint) End Sub
