1114 Views, 4 Replies
Ilogic move drawingdimensions
I am trying to move some drawingdimensions with ilogic, but it is not working.
with the help of the VBA tool i could find the coordinates of the dimensionlines, but it looks they are read-only.
Why are these dimensions read only, and can't be moved with ilogic?
for my code i have a simple drawing that has 4 dimensions on it.
Dim osheet As Sheet = ThisApplication.ActiveDocument.activesheet
Dim oview As DrawingView = osheet.DrawingViews(1)
Dim dimension As GeneralDimension
For Each dimension In osheet.DrawingDimensions
	Trace.WriteLine(dimension.ModelValue)
	If dimension.DimensionLine.direction.y = 1 Then
		Trace.WriteLine("Direction y=1")
		dimension.DimensionLine.MidPoint.X = oview.Center.X - (oview.Width * 0.5) - 0.6
	ElseIf dimension.DimensionLine.direction.y = -1 Then
		Trace.WriteLine("Direction y=-1")
		dimension.DimensionLine.MidPoint.X = oview.Center.X + (oview.Width * 0.5) + 0.6
	ElseIf dimension.DimensionLine.direction.x = 1 Then
		Trace.WriteLine("Direction x=1")
		dimension.DimensionLine.MidPoint.Y = oview.Center.Y - (oview.Height * 0.5) -0.6
	ElseIf dimension.DimensionLine.direction.x = -1 Then
		Trace.WriteLine("Direction x=-1")
		dimension.DimensionLine.MidPoint.Y = oview.Center.Y + (oview.Height * 0.5) + 0.6
	End If
Next
Trace.WriteLine("rule done")
i also tried to create a point2D and then move the MidPoint of the dimensionline to the point. but that also doesn't work
I am able to read out all the values of the dimensionline, so ilogic can find the correct properties.
Trace.WriteLine(dimension.DimensionLine.MidPoint.X & " " & dimension.DimensionLine.MidPoint.Y)
Kind regards,
Geert
