I spent some more time today and finally got it around.
Good for the time being: I need to refine this rule anyway: I appreciate any help because I am not a programmer (just doing mostly with help from forum - thanks to the postings in general).
Sub main		'Function oFix_D3_FG(oDerivedPart, oDN_DwgModelDoc, oDN_woExt_TDMD, oExtn_TDMD, oExit, oCancel)
	oDerivedPart = ThisDoc.ModelDocument		'ThisDrawing.ModelDocument		'
	oFFN_DwgModelDoc = oDerivedPart.FullFileName	'ThisDrawing Full File Name
	oDN_DwgModelDoc = oDerivedPart.DisplayName	'Display Name of ThisDrawing
	oCustomPropertySet_DwgModelDoc = oDerivedPart.PropertySets.Item("Inventor User Defined Properties")
	'Some working parameters
	Dim oSelect_Other As String = "Select from a REFERENCE Document"
	Dim oCancel As String = "Cancel"
	Dim oExit As String = "Exit"
	oName_Para = InputBox("Name of ueser parameter (edit if necessary)", "Title", "D3")	'Name of user parameter reqyuired to be defined
	'Parameters (all in general)
	Dim oAllParams_DwgModelDoc As Parameters
	oAllParams_DwgModelDoc = oDerivedPart.ComponentDefinition.Parameters
	'User parameters
	Dim oUserParams_DwgModelDoc As UserParameters
	oUserParams_DwgModelDoc = oDerivedPart.ComponentDefinition.Parameters.UserParameters
	'Reference Parameters
	Dim oReferenceParams_DwgModelDoc As ReferenceParameters
	oReferenceParams_DwgModelDoc = oDerivedPart.ComponentDefinition.Parameters.ReferenceParameters
	'Create Name_Para user prameter in model cdocument
	Try	'To crete user parameter assigned to oName_Para
		oTry = oUserParams_DwgModelDoc.Item(oName_Para).Value
	Catch
		oUserParams_DwgModelDoc.AddByValue(oName_Para, 0, UnitsTypeEnum.kMillimeterLengthUnits)
		param = oUserParams_DwgModelDoc.Item(oName_Para)
		param.IsKey = True
		param.ExposedAsProperty = True
	End Try
	Dim oList_TargetParamsDwgModelDoc As New ArrayList
	oList_TargetParamsDwgModelDoc.Add(oSelect_Other)
	Dim oList_RefParamsDwgModelDoc As New ArrayList
	For Each oRefParamsDwgModelDoc_X In oReferenceParams_DwgModelDoc
		oRefParamsDwgModelDoc_XName = oRefParamsDwgModelDoc_X.Name
		oRefParamsDwgModelDoc_XExpression = oRefParamsDwgModelDoc_X.Expression
'		oList_RefParamsDwgModelDoc.Add(oRefParamsDwgModelDoc_XName & ": " & oRefParamsDwgModelDoc_XExpression)
		oList_RefParamsDwgModelDoc.Add(oRefParamsDwgModelDoc_XName)
		If oRefParamsDwgModelDoc_XName = oName_Para Then
			'Do Nothing
		Else If oRefParamsDwgModelDoc_XName.Units = "ul" Then
			'Do nothing
		Else
			oList_TargetParamsDwgModelDoc.Add(oRefParamsDwgModelDoc_XName)
		End If
	Next oRefParamsDwgModelDoc_X
	oSelectt_Multiple_for_D3 = InputListBox("LIST OF REFERENCE PARMETERS (MODEL DOC)", oList_TargetParamsDwgModelDoc, oList_TargetParamsDwgModelDoc(0), Title := "ASSIGN VALUE TO " & oName_Para, ListName := "SELECT d23 or A REF. PARAMETER")
	If oSelectt_Multiple_for_D3 = oCancel Then
		'Do nothing
	Else If oSelectt_Multiple_for_D3 = oSelect_Other Then
		oD3_DP(oDerivedPart, oDN_DwgModelDoc, oAllParams_DwgModelDoc, oReferenceParams_DwgModelDoc)
		Dim oList_AllParamsDwgModelDoc As New ArrayList
		For Each oList_EachParamDwgModelDoc In oAllParams_DwgModelDoc
			oName_EachParamDwgModelDoc = oList_EachParamDwgModelDoc.Name
			oExpression_EachParamDwgModelDoc = oList_EachParamDwgModelDoc.Expression
			'oList_RefParamsDwgModelDoc.Add(oRefParamsDwgModelDoc_XName & ": " & oRefParamsDwgModelDoc_XExpression)
			oList_RefParamsDwgModelDoc.Add(oName_EachParamDwgModelDoc)
			If oName_EachParamDwgModelDoc = oName_Para Then
				'Do Nothing
			Else If oList_EachParamDwgModelDoc.Units = "ul" Then
				'Do nothing
			Else
			oList_TargetParamsDwgModelDoc.Add((oName_EachParamDwgModelDoc))
			End If
		Next oList_EachParamDwgModelDoc
		oList_TargetParamsDwgModelDoc.Add(oCancel)
		oList_TargetParamsDwgModelDoc.Add(oExit)
		'oSelectt_Multiple_for_D3 = InputListBox("2. LIST OF REFERENCE PARMETERS (MODEL DOC)", oList_TargetParamsDwgModelDoc, oList_TargetParamsDwgModelDoc(0), Title := "2. oSelect_Other: " & oName_Para, ListName := "2. SELECT d23 or A REF. PARAMETER")
	End If
		param_D3 = oAllParams_DwgModelDoc(oName_Para)		'oName_Para)
		param_D3_Current = param_D3.Expression		'?
		oList_TargetParamsDwgModelDoc.Add(param_D3_Current)
		oSelectt_Multiple_for_D3 = InputListBox("Select for D3", oList_TargetParamsDwgModelDoc, oList_TargetParamsDwgModelDoc(0), Title := "D3", ListName := "User Parameter: D3")
		oIndex_Ref_Selected_forD3 = oList_TargetParamsDwgModelDoc.IndexOf(oSelectt_Multiple_for_D3)
		oItem_Ref_forD3 = oList_TargetParamsDwgModelDoc(oIndex_Ref_Selected_forD3)
		'param_D3 = oUserParams.Item(oItemD3)
		param_Ref_forD3 = oAllParams_DwgModelDoc.Item(oItem_Ref_forD3)
			'Do nothing
		Else If oSelectt_Multiple_for_D3 = oExit Then
'			Return oSelectt_Multiple_for_D3
		Else
			param_D3.Expression = oSelectt_Multiple_for_D3
		End If
'oName_Para = "D3"
'param_D3 = oUserParams.Item("D3")		'(oName_Para)
'MessageBox.Show("param_D3: " & param_D3.Name _
'& vbLf & "param_D3.Expression: " & param_D3.Expression _
'& vbLf & "oUserParams(2): " & oUserParams(2).ModelValue, "Title")
	iLogicVb.UpdateWhenDone = True
	InventorVb.DocumentUpdate()
End Sub
Function oD3_DP(oDerivedPart, oDN_DwgModelDoc, oAllParams_DwgModelDoc, oReferenceParams_DwgModelDoc)		'Public Sub ModifDerivedParams()
		Dim oDerPartComp As DerivedPartComponent
		'Dim oName_SeletedRef_DerivedPart As DerivedPartComponent
		Dim oList_RefDocs_DerivedPart As New ArrayList()
		For Each oRefDoc_DerivedPart In oDerivedPart.ComponentDefinition.ReferenceComponents.DerivedPartComponents
			oList_RefDocs_DerivedPart.Add(oRefDoc_DerivedPart.Name)
		Next oRefDoc_DerivedPart
		Dim oName_SeletedRef_DerivedPart As String	'To select a derived (reference) part
		oName_SeletedRef_DerivedPart = InputListBox("Prompt, oList_RefDocs_DerivedPart: ", oList_RefDocs_DerivedPart, oList_RefDocs_DerivedPart(0), Title := "SELECT DP FROM", ListName := "LIST OF oList_RefDocs_DerivedPart")
		xIndex  = oList_RefDocs_DerivedPart.IndexOf(oName_SeletedRef_DerivedPart)
		Dim oRefDPComp_ModelDoc_Selected As DerivedPartComponent
		oDerPartComp = oDerivedPart.ComponentDefinition.ReferenceComponents.DerivedPartComponents(xIndex + 1)
		Dim oDef_SelectedDerivedPart As DerivedPartUniformScaleDef
		oDef_SelectedDerivedPart = oDerPartComp.Definition
		Dim oDerEntity As DerivedPartEntity
		Dim oList_Params_RefDP_Selected As New ArrayList()
		For Each oDerEntity In oDef_SelectedDerivedPart.Parameters	'Parameters	'oRefDP_Def_ModelDoc_Selected.Parameters
			oList_Params_RefDP_Selected.Add(oDerEntity.ReferencedEntity.Name)
		Next oDerEntity
		'oList_View = InputListBox("Prompt", oList_Params_RefDP_Selected, oList_Params_RefDP_Selected(0), Title := "Title", ListName := "List")
	Dim oShortList_Params As New ArrayList()		'Short list of paramaters from the derived part selected
	Do	'To add selected Parameters To list
		oParam_RefDP_Selected = InputListBox("oD3_DP 1: Prompt", oList_Params_RefDP_Selected, oList_Params_RefDP_Selected(0), Title := "oD3_DP 1: CLICK ''X'' TO CLOSE!", ListName := "oD3_DP 1: Parameters from " & oName_SeletedRef_DerivedPart)
		If oParam_RefDP_Selected = "" Then Exit Do 'If "X" at top left corner hit
		oShortList_Params.Add(oParam_RefDP_Selected)
				oIndex = oList_Params_RefDP_Selected.IndexOf(oParam_RefDP_Selected)
				oDerEntity = oDef_SelectedDerivedPart.Parameters.Item(oParam_RefDP_Selected)
				oDerEntity.IncludeEntity  = True
				oList_Params_RefDP_Selected.Remove(oList_Params_RefDP_Selected(oIndex))
	Loop While oParam_RefDP_Selected IsNot Nothing
	       'Set Definition back, so DerivedPart Document is updated
        oDerPartComp.Definition = oDef_SelectedDerivedPart
ThisDoc.Save
End Function
