Hi. How can I make this work in Inventor 2015? I guess that add-in
0AC6FD96-2F4D-42CE-8BE0-8AEA580399E4
is not found because the rule creates folders but no PDFs. I usually just use the native Inventor export to pdf button, which seems to have the same options as the one referenced in the rule, but not sure if it's a different add-in. I did a google search for that ID to try to find out what add-in that is, but all I found were more rules referring to the same add-in.
Thanks.
