08-21-2019
02:58 PM
- Mute
- Permalink
- Report
08-21-2019
02:58 PM
You can lookup all ExtrudeFeatures and look up the extrusion length.
C#
static void Main(string[] args)
Application inventor = (Inventor.Application)System.Runtime.InteropServices.Marshal.GetActiveObject("Inventor.Application");
PartDocument doc = (PartDocument)inventor.ActiveDocument;
foreach (ExtrudeFeature feature in doc.ComponentDefinition.Features.ExtrudeFeatures)
switch (feature.Definition.ExtentType)
case PartFeatureExtentEnum.kDistanceExtent:
DistanceExtent ext = (DistanceExtent)feature.Definition.Extent;
Console.WriteLine(string.Format("{0} is of type {1} and has distance: {2}",
feature.Name,
feature.Definition.ExtentType.ToString(),
ext.Distance.Value
break;
default:
break;
Console.ReadKey();
}this example works only for a extrusion by a length. In the help you will find a more comprehensive example written in vba. (look for an example called "GetFeatureInfo")
Jelte de Jong
Blog: hjalte.nl - github.com
