HideoYamada
in reply to: martinhoos
Hello from Japan,
Try this code!
Please use freely.
Sub IColor()
    Dim doc As AssemblyDocument
    Dim designView As DesignViewRepresentation
    Dim viewFound As Boolean
    Dim repManager As RepresentationsManager
    Set doc = ThisApplication.ActiveDocument
    Set repManager = doc.ComponentDefinition.RepresentationsManager
    viewFound = False
    For Each designView In repManager.DesignViewRepresentations
        If designView.Name = "IColor" Then
            viewFound = True
            Exit For
        End If
    Next
    If Not viewFound Then
        Set designView = repManager.DesignViewRepresentations.Add("IColor")
    End If
    designView.Activate
    Dim occ As ComponentOccurrence
    Dim index As Integer
    Dim localAsset As Asset
    index = 0
    For Each occ In doc.ComponentDefinition.Occurrences
        Set localAsset = GetAsset(doc, index)
        occ.Appearance = localAsset
        index = index + 1
        If index = 16 Then
            index = 0
        End If
    Next
End Sub
Private Function GetAsset(doc As AssemblyDocument, colorNumber As Integer) As Asset
    Dim colorName As String
    colorName = "IColor" & colorNumber
    On Error Resume Next
    Set localAsset = doc.Assets.Item(colorName)
    If Err Then
        Set localAsset = doc.Assets.Add(kAssetTypeAppearance, "Generic", colorName, colorName)
        Dim tobjs As TransientObjects
        Set tobjs = ThisApplication.TransientObjects
        Dim color As ColorAssetValue
        Dim red As Integer
        Dim green As Integer
        Dim blue As Integer
        Dim high As Integer
        Dim low As Integer
        If colorNumber < 8 Then
            high = 255
            low = 30
        Else
            high = 127
            low = 0
        End If
        If colorNumber And 1 Then
            red = high
        Else
            red = low
        End If
        If colorNumber And 2 Then
            green = high
        Else
            green = low
        End If
        If colorNumber And 4 Then
            blue = high
        Else
            blue = low
        End If
        localAsset.Item("generic_diffuse").Value = tobjs.CreateColor(red, green, blue)
        Dim floatValue As FloatAssetValue
        Set floatValue = localAsset.Item("generic_reflectivity_at_0deg")
        floatValue.Value = 0.1
        Set floatValue = localAsset.Item("generic_reflectivity_at_90deg")
    End If
    On Error GoTo 0
    Set GetAsset = localAsset
End Function
Best Regards,
Freeradical
 Hideo Yamada
Freeradical
 Hideo Yamada
https://www.freeradical.jp
