339 Views, 1 Reply
How Can I Export an AutoCAD Sketch into an Invetor Sketch?
Hello, I have a sheet metal layout, attached below, and I was wondering if there was a way to export this sketch into an inventor sketch so I can cut out each hole from the AutoCAD drawing.  I can export this drawing into inventor, however it is not constrained at all so I can not move it to the desired location within my inventor sketch without the geometry getting messed up.  On top of that, when i export it into inventor, I can not use the geometry to cut, or extrude the holes, I have to sketch holes on top of what I export in.
