How do I control zoom extents. The zoom goes way out and the model becomes almost a dot on the screen.
Solved by josh.goldstein. Go to Solution.
Hi @mbynoe,
It sounds like you've got geometry in your model that is very far from the geometry you're intending to be the "extent" of the model.
After running Zoom Extents, it might be worth trying to:
Zoom Extents is designed to zoom to the extents of your model, so there's no control here other than making sure your geometry is where you intend it to be. In your case, the extents are much larger than you'd expect, so you'll need to track down the problematic geometry and either move it closer to the rest of the model, or delete it entirely so Zoom Extents doesn't have to zoom so far out to capture everything.
Let us know if you continue having issues and we can take a look at the model for a deeper investigation.
