Hi everybody!
someone might have had the same problem as I:(
I have modeled this building in Formit 360 as you can see in the first picture. I also built some railings that I chose to be masses,. I made the lowest one, grouped it and then array'd the rest of them. (I have seen other people so this on YouTube) but when I try to import the file to Revit 2017 I get this message "A serious error has occurred, It is strongly recommended that you use save as to save your work in a new file before continuing" (see the third picture)
I also saved the "building model" from Formit without the railings and imported it to Revit but I do not get the "wrong" message then.
Does anybody know why this is happening?
